VicS
Calcium is a chemical element with symbol Ca and atomic number 20. An alkaline earth metal. Dissimilar metals will cause corrosion as will stray current. A galvanic isolator will stop stray current but not dissimilar metal corrosion.
And the relevance to these facts about calcium is what exactly?
A galvanic isolator will stop currents originating from very low voltage sources, such as dissimilar metals, conducted by the shorepower earth connection from causing corrosion. It will not stop currents originating from higher voltage sources such as a 12 volt system.
