Sharky34
Following on from "which ketch" thread, pros & cons?
Transoceanique built in UK, so is it a true Banjer?Not all Banjer 37s are equal.
Sail areas for the Banjer range from 28m2, 42m2, 62m2, 75m2 to 100m2. The Transoceanique model with the 100m2 has an extra ton of ballast.
The original model started out as a sea-going motorboat with steadying sail to keep the rolling under control. The models with the taller rigs and greater moments of inertia are better at roll attenuation.
The 75m2 model has a SA/D ratio of 14.08; the Fisher 37 is 12.78.
The Banjer displaces 12 t.
The Fisher weighs 14.22 t.
DWL Banjer 10.21 m, Fisher 9.91 m
From the 75m2 model on-wards my money would be on the Banjer as far as sailing ability goes.
Here's a good video of an F37 with all the rags up:
The Fisher 37 without the bowsprit can be under powered when sailing. Bowsprit boats from the factory had a slightly taller rig than earlier boats also giving around 1000 sq ft of sail as a cutter/ketch.
There are also changes to the interior layout of the F37 over the years with increased interior volume and better galley (down the std quarter) as years went on. A few of the last ones had an aft head, bigger fore cabin and two wheelhouse side windows instead of three and I think were known as the Fisher 37 Deck Saloon.
