sailorman
Best read #9 thenMarine ball valves for water are good also for fuel. Do not use PTFE because diesel melts it. I used sikaflex successfully. Sikaflex is not affected by diesel or solvents once cured.
Other say it is because it melts. If the latter than all ball valves using a PTFE seat would be a no go and rule out a lot of marine balls valves.
A fuel cock will usually be before the engine's fine filter, is there much realistic chance of strands of PTFE getting past that?
If you want some further reassurance, this chart says that PTFE is "resistant" (the highest option) to diesel.
PTFE is almost totally inert, and is not attacked by diesel fuel, or any other kind that I know of. It's the tape that's the problem, small fibres of it will inevitably break off when making joints up and some may well find their way downstream. I have some dramatic photos of a gas turbine that burnt and destroyed itself when a piece of PTFE tape became trapped across one of the combustor nozzles, diverting the flame path.
I helped a workmate a long time ago to do an emergency repair on a petrol carb.with ptfe tape and the petrol dissolved the tape quick time.
