Seajet
The situation is that I want to leave the boat in shallow water while I fetch or deposit the trolley. No problem with crew - one person holds the boat. Much harder, singlehanded.
If the wind blew offshore, the breakers would be so slight that I could leave the boat half-in, half-out, resting in little danger...but that is almost never the case, and I've often had to leave her graunching horribly on the steep shingle beside the slipway.
If the wind blew offshore, it would be much easier - I could just tether the boat to a tree or bench ashore. As it is, I think a hefty grapnel will work very well - the beach is pebbly over soft mud.
I suppose I'll have to get the boat in the water, then hurl the opened grapnel as hard as possible offshore, on about 30ft of line. The water is rapidly too deep to stand in, so a shorter line risks the grapnel not biting...although, if I get it wrong, the length of the line will let the stern of the boat run ashore, and the same will happen if the grapnel drags.
The appeal of the stone-bag was the shortness of the warp required...although a large dinghy tugging horizontally on a nearly-vertical line, would probably have moved a much greater weight than I'd want to have to load and unload each time.
Trial and error will be the test.![]()
Hmmm,
I've tried throwing an anchor and chain out, from the foredeck of a boat I was trying to help, pinned against the road bridge; despite the adrenalin of the situation my attempts were pathetic, about 10' !
I suppose with practice and twirling the grapnel on the line like something out of a cartoon one might do better, but there might be a field full of dead and dying like the battle scene from Gone With The Wind before one perfected it...
