K-ron
Hi,
I have recently installed my home made wood burner on my boat. Unfortunately the stove is not drawing as well as I would like. After lighting some small pieces of kindling with a fire lighter the wood started to just smoulder rather than burn. It doesn't really change much when I open the ash door at the bottom. This leads me to believe that it's simply not drawing properly. The stove is made from 8 mm steel box section with top and bottom plates of 12mm there are two air vents one on the ash door at the bottom and one at the top of the fire box. I have also installed a 12mm baffle plate 2 inches from the top plate, welded on 3 edges with a gap of about 1.5 inches for the smoke/fumes. The baffle is welded horizontally not on an angel. Could I have made the baffle to big? Could this be stopping the flow of air, pushing it back down into the fire box? The flue is 2 inch thick walled stainless and the length is 1 meter. Any suggestions as to the problem before I resort to chopping the top off to change the baffle design?
Cheers
Kieran
Cheers
Kieran
