HeadMistress
Re: Bad odour coming out of toilet at first flush!
Your questions valid.
It's a mistake to equate marine toilets, hoses etc with household systems, hot tubs etc..'cuz not all rubber is created equal...some is formulated to be more resistant to chlorine and other chemicals than others. Neither are hoses--as many people have learned after choosing to save money by re-plumbing with hot tub hose instead of sanitation hose. The rubber in toilets is not the same as rubber in hot tubs...hot tub pumps don't subject rubber parts to the friction that marine toilets do...plus, I think if you do a bit of research, you'll find that rubber parts that are exposed to chlorine and hot tub chemicals actually require considerably more service than you think. The difference when it comes to marine toilets is one of expectation...household toilets require -0- maintenance, so most owners today expect marine toilets to need none either.
You're quite right that a bucket would be a much simpler system, much easier to maintain...but it's not what people want these days...they want everything on a boat to be "just like the one at home." No one wants a BOAT any more...they want a floating condo!
As for how to clean your toilet to protect from e-coli and other nasties...they don't climb OUT of toilets, so I think you're safe from all of 'em if you don't drink from the bowl. /forums/images/graemlins/smile.gif But if you really MUST "disinfect" it (Don't tell me that our national obsession with eliminating every "germ"--good AND bad--on the planet has also infected the UK!)--which, btw, only lasts till the first new flush...by all means, do so..just don't flush the disinfectant.
To clean my own boat toilets... I kept a couple of sponges and pair of rubber gloves in a plastic bag just for the that purpose. All I did--or thought I needed--was to wipe out the bowl with powdered cleanser when the bowl began to show signs of needing cleaning. The small amount of residue left in the bowl isn't enough to make any difference when flushed to rinse.
