PAPOFCARDEN
I own an elderly Dufour Safari which is suffering from water leaking through the deck onto my VHF radio, switch panel and galley. This leak only occurs starboard midships. I've done the obvious and checked all the externals and have decided to drill several holes and inject the hard lining above the affected areas with polyurethane foam. It won't cure the leak but at least stop it from wrecking my electrics. My question is which is the best quality foam to inject? Injecting the deck above is not an option.
