goeasy123
Yes. That idea is going in the right direction. Something I can connect across the 12v system with the LA disconnected would work, but I might need more current carrying capacity than the V IP22.Does this power station provide a 240v supply? In which case you could use something like a Victorian IP22 charger set to PSU mode to supply 12v for the boat. But it's an expensive and inefficient method.
Powerstations have 240VAC consumer sockets on them. You can connect them to the boat system just by plugging them into the shore power supply, but that doesn't solve the current bottle neck through the inverter/charger on the boat. The limitation of a powerstation is that they don't have a high current 12vdc out.... just car cigarette lighter capacity.
I was thinking for building my own powerstation a la Will Prowse, which gives me direct out from the battery. See here
