dial-a-monkey
I'm planning on a long distance sailing trip and I want to have a backup for my LeCromble Schmitt(LS) Hydraulic pump and Cylinder.
The price LS want for a few random parts IS arrogant et ridicule!!
So I started looking for alternatives but discovered it's complex.
Any advice on matching a reversing pump to a double acting cylinder? can anyone suggest a good pump/cylinder combo? As it's just for a backup I'll probably buy used parts off ebay and service them before departure.
Did I miss any considerations below for a pump/cylinder match?
(1) Displacement of the cylinder VS stroke? (my LS max displacement is 432cc for a 485mm stroke) - how to match that against the pump? Should I aim for the current setup?
- Is it ONLY the rudder sensor that stops the pump from forcing the piston past the max stroke? what happens if it's faulty? - relief valve - then fuse?
- Does the Autopilot learn the pump rate (and adjust the PWM) and when to stop from the pump/rudder sensor?
(2)Speed of the pump? (LS is variable at 0.2 - 2 Ltr/min) is this figure crucial to avoid over active steering? should I aim for the same as the LS?
- What would be a good specification for ((Max Cylinder Displacement / Stroke) / by pump Flow Rate)?
(3)Current load - 8 to 13 AMPS
(4)Mechanical load (currently 750 Kg)
(5) Electronic bypass valve? I guess the reversing pump must have an electronic way to engage the cylinder or the manual/wheel steering would always force hydraulic oil through the pump damaging it? But B&G pumps don't seem to have it?!!
As always I'm very grateful for any advice - thanks.
