Travelling Westerly
My current setup for charging my start and house battery is via a mains powered Sterling 30A smart charger dual output connected to the start and house battery for when on dock mains supply. When engine is on the alternator is charging the start and house via a Victron Argo Diode battery isolator so pretty standard stuff so far.
I understand that I can gain a more complete charge for my house battery by using a B2B charger rather than the alternator. I understand how the B2B works but think I have spotted an issue in that when Im on the mains charger (engine not running) the dual output will be charging both batteries and hence the B2B charger will see the charge input on the starter battery, think the engine is running, and will then try to charge the house battery at the same time? Have I got this right?
If I go this route do I need to disconnect the mains charger output to the house battery and just use it to charge the start battery and let the B2B to take care of the house battery? How do others use a B2B charger and is the extra money spent on this B2B worth it as opposed to just charging both via the alternator?
