Topcat47
OK. I bought a three part extending pole from B&Q and said I'd report back at the end of the season.
It's not been an unqualified success. The Pole extends to 12', but I found that if I extended it to more than 9', it tended to buckle. I straightened the part that buckled once. By juducuiously extending it, with the outer section not as far as the failure point it has survived the season, however, it is obvious that you'd not be able to use it in winds stronger than F3.
A further problem on my boat was that the Fwd baby- stay interfered with the pole when the boat rolled. I tried to fix the whisker pole on the spinnaker ring, but this only made it worse. I'm contemplating using some shock cord to keep the clew of the sail down, next season. /forums/images/graemlins/blush.gif
