B&Q outboard £60 ??!!
pcatterall
2 Aug 2004
Nearly bought one, they are made by Homelight who made a 55hp 4 stroke which I used in Nigeria many years ago.
Then I realised it was a strimmer!! Then I thought if I could fit a prop it would be an outboard !! How much power from a 25 cc engine??.... Well... it looked nice!!
JKay
24 Jan 2005
/forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
cheers Joe
Others may laugh .... but you are not first to look at a strimmer as a possible power plant for a prop.
Also as a generator power plant as well ....
Swanrad2
16 Aug 2005
Cheshire
Remember seeing an 'outboard' on an Amazon river boat that looked exactly like a strimmer with a long thin felxable leg, dipped in and out of the water to steer and avoid logs and stuff....
gag
6 Jan 2006
you used to get outboards for canoes that are strimmers with props like a small version of those "longtail" Thai car engined boats with long propshafts.
MASH
N/A
8 Mar 2004
25cc should give you a bit under 2Hp I'd have thought. Pretty useful in a small boat, but RPM might be too high for a prop.
graham
I remember a guy in Ireland posted on here about a strimmer conversion. Apparently amid clouds of smoke screaming engine and spray he accelerated eventually up to about 1 knot /forums/images/graemlins/grin.gif
doug748
1 Oct 2002
UK. South West.
Early (60s / 70s) Ocean outboards had a straight leg which did away the need for a gearbox. A bloke in PBO "powered" his cat with a modified brushcutter (bout 15 years ago). Nothing new under the sun, eh.
Swanrad2
16 Aug 2005
Cheshire
I've got a rusty cement mixer with a petty engine and I never intend to mix any cement ever again 'cause I'm not very good at it, what do you reckon the chances of converting that are? Slower rev's,anyway,
Evadne
27 Feb 2003
Hampshire, UK
But he did admit he'd have gone faster rif he's fitted a propeller.
