b&q generator
I even blew the lights in my laptop screen with a 12-19v inverter! So would suggest great caution with laptop. I think I would charge the boat battery then plug in a 240v inverter then the laptop 240 volt charger. I think noise levels are quoted at a specific distance often different makers use different distance. The decibel Db figures may be unweighted (higher number typically 91 Db @7m ) or "A weighted" (lower number reflecting human audio perception typically 60Db @7m)
780watts max 2 stroke
only drawback i thought very loud db figours 91 but i have not started it yet. but it is only there if everything else fails.
my question is can i plug a car battery charger into it and charge my batteries up with it? i know i wount be able to plug lap top into it, but if i plug a surge protector into genny and then plug car battey charger into surge protector do you think this would be ok, your comments and suggestions please.
Hi,
Most of us that have the cheapo gennys have gone down the 'Kipor' route. ( A Chinese copy of the Honda) If you have a unit that generates a full sine wave output (as stated on the box) you should be able to run a laptop or any thing with a motor.
To charge 12 volt batteries, they have a 12 volt outlet to use rather than the mains 240 volt, although you could of course use a 240 volt battery charger. The noise levels change dramatically depending on load. The Kipor is very quiet on tick-over and light loads but sings a bit with a kettle on (1500 watt) but that's on a 2Kwatt version. /forums/images/graemlins/blush.gif
In your case, I think you would be well advised to check battery charging ability and run eveything off the 12 volt circuit.
At the sort of price you paid, if it works a full season, you've had a result. /forums/images/graemlins/cool.gif
