CaptainBob
Being from Yorkshire as I am, and having a tin of exterior varnish from B&Q in the shed already - when it came time to do some coats on my brightwork the solution seemed obvious.
But now, a very damp month or two later, it's clear that this varnish has bonded with what was already there and deteriorated. Dark marks are appearing, and I can very very easily remove what seems like all of the varnish layers using just my fingernail, without much effort.
Here's a pic:
You can see where I scraped with my nail on the right, a dark bit on the left and centre, and a (so far) untouched bit below.
If I sand it all back and then stick a few coats of decent marine varnish on, will the dampness in the wood be a problem?
I used to use a bottle of dark brown low viscosity stuff on my Centaur that soaked deep into the wood and could be applied even when the wood was wet. The finish wasn't shiny, but it worked very well. Only problem is that it was very dark brown, which wouldn't go with the look of my Tempest - which is a much lighter colour (as seen in pic).
What should I do?
Here's a pic:
What should I do?
