rafiki_
Thanks Trevor. Lock washer then. Problem is, I guess the clamping load goes when the anode erodes?Loctite blue is likely 243 which is medium strength and will tolerate mild surface oil contamination, whereas 242 won't tolerate oil. The next up is 270 which is green, if you use 270 there is a possibility you will not undo it even when you want to.
If you want added security then using loctite 243 plus a split washer is about as much as you can do.
