Avon Jet Rib 320 - Owners Manual
Hi! I am looking for the manual to avon 320 jet sc (the jockey seat version). I cannot find it online. Does anybody have it in pdf? I would be very thankful! :)
Hi all I know this is an old thread but I’m in desperate need of wiring diagram for a 2001 320 seasport handle bar Avon jet rib !! All wiring was disconnected or cut off , have done the obvious wiring just a few bits left to do ! And also can anyone tell me where the speedo gets it’s info from , the back of the dash has what looks like a pipe cut if at an angle as If it was the old water pressure style pickup but it’s a digital display ??
check carefully at the back plate and the aft end next to where the jet comes out. There's a small classic style wheel that spins and measures speed. Unless you start pulling it out on the sand (you got to be v.strong to get the whole thing out :) ) I bet it's still fine and spinning. There are two cables from there coming to the dash.
The pipe you describe is indeed there doing (afaik) bugger all - probably there to drain any humidity or whatnot from the instrument. Check on my writeup on the other thread you posted the resistance values, get a 1-5KΩ potentiometer, and test which cables run what. Mind undoing the rear seat you can spot the colours of most cables coming from back there (fuel tank-speed) so should be fairly easy to find the rest.
Attaching (if it works!) the page with the wiring dia of the larger sibling 320-400 with wheel. The bits that you want I bet are the same, hope colour coding helps you sort it out.
Good luck!
Hi all. Im hoping i can find someone on here that can help. Desperately looking for an owners manual for 2006 Avon Seasport 320 DL jet and cant find anything online. I would be most grateful for any help with PDF copy if possible.
Very best regards
cmcquaile@gmail.com
