DownWest
Yes, but that then needs machining with a shoulder on the tiller arm, then a reduced diameter for the rose joint. Sort of defeats the idea of just bolting it through with a spacer to hold the rose joint off the arm and still has the possible weak points of machining a bar.The section of steel going through the tiller arm can be bigger than the pin that goes through the rose joint.
