autohelm wind intrument
johnmuir
30 May 2001
No readind at instrument i.e direction or speed. Power to intrument ok as digital wind speed ok. Last year measured viltage at deck from mast head unit and got reading/voltage. Join below mast choc block connector. Any similar probs. or could some one give details of wiring. Unit is older type normal size non the newer narrower model.
thanks john
jfkal
17 Aug 2001
Singapore
Do you get "00" or "--" in the speed display? Is the direction on 0 dgrees or somewhere else?
-- and ) degrees indicate no signal at all and I would suspect wiring. 00 and direction aiming somewhere in the wrong direction indicated the sensors are wrong (they pack up often and cost a fortune to replace :((()
pwc51
23 Apr 2003
Dorking
You don't mention the model etc - we have ST50 and when first installed (10+ years ago) we were getting all sorts of problems. After having the instrument and the masthead unit checked and changed it turned out to be the masthead block so we had to change that and the cable running down the mast. After that we have had no problems until this year when the masthead unit required an overhaul.
Piers
2 Jun 2001
Guernsey, Channel Islands
www.playdeau.com
Try calling the guru of these instruments - Dave Wellcome of Raymarine, software development engineer, and someone who has helped countless 'forumites'. His knowledge seems boundless.
02392 693 611 extension 1614.
<hr width=100% size=1>Piers du Pré
http://www.dupre.co.uk
Athene
28 Mar 2003
Norway
Hello!
I had a ST50 wind instrument installed in 1995. I once did some measurements on the signal cables. May be this could be of any help:
screen-red: approx. 8v (supply voltage?)
screen-yellow: 4-8v depending of wind speed
blue and green: signal depending on wind direction.
I have twice replaced the small masthead PCB-board. On both occations both wind direction and speed indication was "dead".
Regards
Athene, Oslo, Norway
