Richard10002
Covering some old ground here, but some fresh ideas may be available.
When I press "AUTO" on the ST7000 control panel, it shows "LOW BATTERY", and wont work.
I have measured the voltage into the computer, and it's over 12v, (usually over 13v). I've also attached a spare ST7000 controller to the computer, and get the same display. The ST60 multi function display panel also shows 13V or more.... the multi function panel seems to get it's power from the computer.
The above suggests that it isnt a problem with the control panel, (which is the usual problem from reading other posts on this), and the fact that the computer is getting over 12V makes me guess that there is something wrong inside the computer.
The following is Raymarines' answer to a similar question:
"I suspect that your problem is related to a local voltage drop at the course computer. This could be caused by either low battery bus voltage, insufficient wire size to the course computer power supply, too small of a circuit breaker, or corrosion on the power supply cabling.
The corrosion problem is most common if the pilot has been installed for any length of time. Undersized power cabling can also be a big player. The wire becomes less efficient as carrying electricity as it heats or becomes corroded. This would explain the pilot working for the first 10 to 20 minutes of operation.
Make sure that the manual's specification for wire guage and length of wire runs was followed on the installation. Also, make sure that the correct breaker size was used for the course computer."
from here:
http://raymarine.custhelp.com/cgi-b...nNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1
Any ideas as to what the problem could be?
Could the computer be getting less than 12V, even though a meter at its' input shows over 12V?
Is it still possible to get these computers refurbished by Raymarine?
Any ideas where I might get a replacement computer? (I'm searching ebay on a regular basis and also doing a regular google search).
Replacing the computer with the latest models would mean replacing the controller aswell.... probably about £2k or more, and the latest ones wont fit in the existing space, so a major job which I could do without
Many Thanks
Richard
from here:
Many Thanks
Richard
