Fantasie 19
FWIW I was able to clean up the thread in the pushrod using the tap by pressing it hard laterally into the thread, the result is very good and smooth so it absolutely definitely is 19tpi but the 3/8 BSP tap is definitely under sized by a fraction. There is no way to use the die to repeat the process to clean up the threads on the extensions.
I think VicS measurement sounds about right. Perhaps this is simply a non standard thread that some machinist knocked up one day and it has stayed the same ever since ?
...which also ties you into buying from them and not making your own.... they aren't owned by Apple are they?
