nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
So what you need is a SeaTalk output from a GPS? How about an NMEA to SeaTalk converter?
Am I in the right place to ask this question? If not - sorry - please redirect me.
My Autohelm ST50 Plus Nav system is showing what can best be described as an internal power problem.
Switching on after a protracted period of none use, I am requested to re-enter the CodeLock. This done after a short period the system comes up as normal. Provided I switch the system on every couple of weeks these systems do not reappear but leave it longer and it is back to square one.
My question, does the system have an internal (memory) battery? If so, where is it and is it easy to source and replace?
Hi Richard.
Many thanks for this info.
The system is very simple (bit like me), no plotter or radar, just basic instruments so hopefully shouldn't be too difficult to sort.
As I am going from new (proper plug/socket) terminations into old bare cable connections, my only problem is identifying the cable colour code within the plugs. Again a bit drastic but I have a spare spur cable lead so I could cut into it to confirm how the club is connected up.
An aside, having read that light aircraft are increasingly using tablets, rather than a plotter, I use a stand alone iPad with GPS/Glasnost data to provide track information.
Early days but seems to work well.
Once again, many thanks.
C
If it's any help, the connectors on the original Seatalk (and possibly STng but you could check on Google) are actually just standard 2.8mm spade terminals. I bought a pack of insulated crimp male ones from Halfords when I re-wired my Seatalk in 2016 and simply crimped those onto the cables and used them instead of the proper Seatalk connector. They just push onto the blades in the instrument port and seem really solid.
Richard
