rhumlady
I hate button cells with a vengeance!(?) The number of pieces of kit I have both at home and in my work as a computer engineer which work fine till the battery dies then after replacement you get problems and short battery life. I do use nitrile gloves when changing them but still have problems. I now put it down to bad quality control but why they work out of the factory is any ones guess. Having said all this my pal has a 2 year old Mondeo which has a keyless ignition, you have to have a keyfob within range and the car will start when the button is pressed. He got the battery swapped under warranty and it lasted 2 months before reporting low battery again. This got me checking the routine for my Freelander keys which require me to remove the battery and press the buttons for about 10 seconds to discharge any residual current prior to putting the new battery in. This would effectively hard reset the fob. I think that is what has maybe happened to your compass when you left the battery out for an extended period.
Rant over.
Rant over.
