sheppard
This has defeated the 'experts' so the forum is the obvious choice...
My tiller autohelm (4000+) extends in short bursts of a second or so to its outer limit, then blows its fuse, whenever put into 'Auto'.
In 'Standby' its sense is correct and it works fine, the + and - buttons resulting in correct extension or retraction of the motor arm.
The compass read out on the Autohelm unit reads correctly.
My local experts said they could replace it all for the new model for about £1,000. I believe they probably could.
Raymarine say there is no fault on the control unit. They suggest the motor unit may be faulty, but it responds correctly in 'Standby'. Someone said the compass might be faulty, but it reads accuractely. All the wiring connections look pretty clean and secure - at least there are no corroded lumps anywhere I can see.
There are other Seatalk instruments in the system, but when the Seatalk plugs are removed from the Autohelm, nothing changes (except the other bits turn off of course).
Has anyone had a similar problem and found a fix?
