autohelm 3000
I have an autohelm 3000 which I wish to interface to a GPS.I cannot find anythng available does anyone know of a design or whatever.
If the Autohelm is a Seatalk model i.e. ST3000, you will need an Interface Box. This can probably be obtained from ??whoever (Someone supply the name please) has taken over Autohelm.
If the 3000 connections are similar to my 2000, I can email you the connection diagram. If it has a three pin plug/socket, two pins are + and -, and the third is data. This goes to the interface box, which is between Autohelm and GPS.
regards,
Philip
The interface you require is supplied by Raytheon. Pt No E85001. RRP is £110 + vat
we can supply if req. Can also supply copies of tech. manual.
kev
www.yachtbits.co.uk
