Auto pilots
hlb
RIP
Any Pub Lancashire or Wales
Bit of a silly name but any way. You need to set the auto pilot up to the boats speed and capability. No good asking it to do a 90deg turn if the boat cant do it or you will be way off track and the Auto pilot will just complain.
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
D
Deleted User YDKXO
My previous boat did the same and I put it down to the fact that there is greater pressure on the rudders at speed. If the Simrad is like the Autohelm pilots, could be you need to increase the response and/or the rudder settings. I believe this will make the pilot respond earlier to course errors and make a larger rudder movement. It worked with my boat
jimg
30 May 2001
Dartmouth
They need to be setup properly, I cannot remember the details now but it is all in the handbook. You have run in the setup mode at slow speed and then at high speed for it to learn the characterictics of your boat. Which model do you have and have you got the handbool?
oldgit
6 Nov 2001
Medway
My Autohelm has adjustment to give greater helm inputs at low speed and less drastic ones at high speed.
<hr width=100% size=1>If it aint broke fix it till it is.
jimg
30 May 2001
Dartmouth
Simrad work differently to Autohelm and have this more complex setup system. I have had 3 previous boats with Autohelm and to start with I did not like the Simrad, but now I am quite pleased with it. It tracks perfectly at low or high speed in all conditions. I suspect his Simrad has not been setup properly.
Renegade_Master
27 Jan 2003
Spain
Your autopilot doesnt know what its like to go over 20knts anyway/forums/images/icons/smile.gif
<hr width=100% size=1><A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
Andrew38
6 Jul 2003
Yorkshire
I have a Simrad autopilot on my Broom 38. I had the opposite problems - fine above 25 knots but drifted all over at low speeds.
Mine self selects into Hi and Lo speed settings -- is yours doing this?
By adjusting the Sea State setting through the menu I solved my problems
My best suggestion would be to call Simrad in the UK they have always been helpful and knowledgible.
