wipe_out
I have a standard setup with two batteries and a O-1-2-B switch.. No real need to change anything because it all works fine for my needs but I usually run on battery 1 as a habit and often forget to switch to both or 2 when the engine is running to top up battery 2.. Or if I do I forget to switch it back to 1 or 2 when anchored.. Fortunately no flat battery issues yet..
Anyway.. I am looking to make minimal changes but auto charge the second battery.. So I am thinking of simply adding a VSR to the two batteries and that's it, everything else stays the same..
Are there any issues I should be aware of doing this?
Is there a better/simpler way to automatically charge both batteries that doesn't involve changing the system much?
