Auto bilge pumps- a waste of money? (very long)
andyball
1 Jun 2001
I'm sure we all agree that a typical, or even several large bilge pumps won't save a boat with a major leak; by which I mean a 2" hole, say 2' below the waterline. But a 1" hole...same depth shifts maybe 1500 gallons per hour, which on a boat with 2 largeish pumps is surely sustainable until the batteries run low.... indefinitely with shorepower....is that pointless to have?.
Do all sinkings due to leaks happen only with major leaks? what about one that lets in say 150 gallons per hour on average? many boats would sink if that continued for a day or so (few would escape some water damage,I imagine), but even a small pump, combined with shorepower & a charger (many boaters do have this luxury), would cope with it.
Thorough & detailed tests of small (as in not great commercial things) bilge pumps are thin on the ground....they're not exactly scintillating reading, so even if carried out, few would be fully published in magazines.
Based upon my own experience with a "2000 US gallon per hour" pump actually making 1200 imperial gallons p/h at 12.4V (a modest lift & length of pipe by boat standards, but normal for a 22' sportsboat) .....75% or less of claimed output is normal.
A huge & thorough-sounding test by West marine in '99 found some that made 92-104 % of their claimed rating, with 3' lift & 6' of pipe, which is rather better than mine, although only 50% of those tested managed 75% of claimed output.
The same test also looked at efficiency; & although details are sketchy, the summary in their 2002 catalogue claimed a flow (with lift,pipes & skin fitting) of between 13 and 30 US gallons per hour for each measured Watt of pump power.....so an imaginary "toy town" pump pulling say 2 Amps (25Watts'ish) might pump 325 to 750 US gallons per hour. A test in PBO June 2002 claimed results between 10 and 20 imperial gall's per hour,per Watt,which sounds very broadly similar; although this was based upon claimed current draw, not measured Amps.
Assuming that West Marine were exaggerating (no reason,just assume it) I'll say just 200 imperial gallons per hour, although the reality might be much larger according to west marine.
Take an imaginary boat with one of these imaginary (but based on west marine's tests ) pumps that pull's 2 Amps or there abouts......the pump will draw 2AH from a battery if it runs for an hour & pump 200 gallons in that time.
Same imaginary boat has a "spare" 40AH of useable battery capacity ( made up notionally by assuming a fully charged 90AH battery that's lost a bit of it's capacity ....quite a (very?) small amount by many boat standards ?. The pump would run for roughly 20 hours before the battery was flat & in that time remove maybe 4000 gallons of water. (The west marine tested pumps drew less current & pumped less water at low voltages, but became more efficient, so the gallons vs Amp Hours figure should stay similar,even though the battery voltage would drop steadily)
" a pint of water weighs a pound and a quarter " I was taught ?...so a gallon must be 10lb's & 4000 gallons must be 40000 lbs or 18 tonnes 'ish.....easily enough to sink a small boat & do plenty of damage to many larger ones if you waited 'til you arrived at the boat to pump it out. This is 640'ish cubic feet of water....similar to a 10' square, 6' deep swimming pool.
Even if you scoff at only 3' lift & 6' of pipe in the west marine test & therefore & halve the amount pumped, not having 9 tonnes of water inside your boat seems reasonable enough.
<font size=1>Actual tests not completed...your mileage may vary.<g></font size=1>
If you get a big leak & don't check the boat for ages; it'll sink regardless of a tiny bilge pump. But...many boats have rather more than 40AH of useable battery capacity, and pumps rather larger than my imagined one are available, and you could fit more than one.
With a proper leak & no shorepower/charger, you're still underwater ; but very many boats do have these ....& many are berthed in staffed marinas who might notice a warning buzzer/flashing light/constant pumping & investigate.
If you're absolutely certain your pride & joy will only ever get really big water leaks, or none at all.....auto-bilge pumps are a waste of money.
So: some big assumptions? based on a test I haven't got all the details of, using (by 35' boat standards) a shortish amount of hose & very modest lift,ignoring inefficiences caused by starting/stopping with the float switch & water running back down the hose when the pump's off. All worthless then?.
I took the figures from the least efficient pump west marine tested, based the figures on the smallest pump generally available (500gph/25W'ish ),reduced even those figures by about 30%, & assumed a quite minimal battery capacity. Take the figures & halve them again for good measure & they still suggest 9 tonnes of water could be outside a boat, rather than in it. Halve them once more, it still looks worthwhile.
Enough imagining! do real life boats,reasonably well maintained -or not, given that even the best make mistakes-ever leak "modest" amounts of water (talking up to 2 gallons a minute here, which may not look modest when you lift a hatch). Ever had a leak that wasn't there when you left the boat ?....how big?. What about smaller leaks, un-noticed over a week or more away from the boat? Don't seacocks, skin fittings ,shafts, rudderstocks etc ever leak unexpectedly?. Or is a disastrous hole that'll sink her in 15 minutes the only way these things work?.
If boats are like cars & bikes (fixed many more of those), then sometimes, even with the best of intentions & maintenance, things can go wrong unexpectedly.
I only mention all this because (apart from insomnia,of course, it's 4.30AM !), auto-pumps, esp with warning lights/buzzers, seem quite useful & practical to me, even with modestly-sized pumps/battery capacity.
PS :if I've missed a decimal point or two & come up with ludicrous figures......it's the late hour - I'll laugh too.
MainlySteam
24 Jul 2003
Not me again!
I will stay out of any contentious issues and just pass along observations (my intention in the other thread was not too denigrate auto pumps but to point out their limitations).
- In making the decision one has to understand that the pump will not run forever. If ones batteries will run it for 2 days and you visit the boat weekly, it is only the last two days of the week that the boat is fully protected to the extent of the pump's capacity. I am not aware of any boats having sunk in our own marina over 5 years we have been there, however I have personally intervened with 2 that were on their way - both with auto pumps which had run out of battery, interesting as I believe that the majority of small pleasure vessels out here do not have auto pumps (certainly pleasure yachts are rarely so fitted).
- It has been commented that the running of a bilge pump (I assume by observation of the water being pumped out) is an alert to others that the boat is threatened. In my experience this is not so, at least out here, where many boats have water cooled condenser units for their refrigeration which run intermittently and are commonly left on in the marina. In 8 months of our own living aboard in one very friendly marina, with the freezer cycling every day, only once did anyone check if it was my bilge pump and therefore a cause for concern - maybe others are more diligent in the UK?
- In my experience, in a boat with properly fitted systems, leaks rarely occur when the boat is inert and closed up without any evidence of there being a leak or a possibility of a leak beforehand (possibility being brought about by such as boatyard work having just been carried out that invades the watertight integrity of the hull eg earlier in the year we had the lip seal replaced in our shaft log seal, it was watched like a hawk for the 2 weeks we spent on board straight after, and whenever we visited the boat for quite some time).
- Alot (and alot!) of boatowners do not close their seacocks when they leave the boat.
- In my experience, most leaks which start to threaten the boat are picked up by the attitude of the boat - liveaboards especially (which are encouraged in our marina for just such security), marina staff or other boatowners notice the antifouling sinking below the surface. The owner of the boat next to us is overseas for 6 months and while he has a liveaboard checking his boat, we as well as others always eye it up too - the best kind of security. More of a problem if one is on an unsupervised mooring.
- I like the idea of a flashing light that was suggested - I have also heard of, but never seen, a marker board being hung over the side of the boat with instructions that if it bottom hits the water "please panic" (again not so useful if in an exposed mooring, because of waves and solitude, rather than in a marina berth).
- In my experience and despite common folklore, hoses do not come off hull fittings - in fact they are normally next to impossible to get off without serious intervention of heatgun or other tool - nor do they split if anything like a respectable material is used in the first place (engine hoses with hot water in them possibly excluded).
In our own boat, if there is any leakage while the boat is inhabited the bilge alarm will go off after a little more than 1 litre has leaked in.
Hope that is of some value, I will go and find some others to annoy now!!!
John
tr7v8
30 Nov 2001
Kent
OK to chip in my 2Ps worth.
It is a condition of my insurance that I have an Auto bilge pump.
Although mine doesn't leak water (touch wood), it does pick up rain water, presumably off the canopy and that puts an inch or so of water in the engine bay after a heavy 12 hours of rain.
I believe that a lot of boats that sink, do so because of rain water penetration rather than hull based leaks and this is covered by an auto pump.
Finally a whole range of switches are on the market that do not leak current into the water so not convinced on the electrolytic bit either.
Finally someone a year or so ago tested a whole range of bilge pumps in PBO.
<hr width=100% size=1>Jim
Draco 2500
gjgm
14 Mar 2002
London
read an article, on BoatUs.com I think, on this topic. Yes, you would appear to need an aweful lot of bilge pump to stop a boat filling up with even a small hole. And somewhere practicality has to come in. Saving lives is the ultimate priority, I guess, not necessarily saving the boat (but of course they may end up being the same, if the boat actually sinks-but would it?).
Gordonmc
19 Sep 2001
Loch Riddon for Summer
One aspect I have not seen mention of yet is water ingressing in the form of rain. Like many classic designs my boat does not have a self draining cockpit. More rain gets into the bilge than seawater via plan seepage and sterngland drips etc.
Obviously the amount of rain getting in is limited by a cockpit cover, but things 'appen.
Rain might take a long time to sink the boat but I can't see that an auto pump, fuse protected and kept seperate from the switch panel circuits presents a hazard.
Talbot
23 Aug 2003
Brighton, UK
Lots of posts about bilge pumps with good info to be able to draw yourown conclusions, but nobody has talked about the division of the boat into separate sections, such that a leak in one section will not completely sink the boat. Surely this is the best preventative. The next most obvious thought for the day, is that imho one of the biggest dangers today is in hitting something (buoy, sunken cintainer etc.) A lot of boats have a separate watertight section at the bow to try to cope with this, but I worry that this may not be enough if I am at full speed. I will be fitting bulbous bows this winter for two main reasons - the added safety, as well as the performance benefits.
Mirelle
N/A
30 Nov 2002
Interesting line of reasoning
One thing I would add is that I think that most boats start to sink faster as they submerge. Of course, all through hull pipework, whether in the topsides or the bottom, "ought" to have a seacock on it, and the seacock "ought" to be closed.
However, this is not always the case, so as the boat settles the rate of ingress increases. Which is an argument for an automatic bilge pump.
My resistance to the idea is driven by an allergy to volts in bilges, however.
I may have been lucky, but in 30 years I have not yet had a boat sink on a mooring. I suppose that since I get down to my boat most weekends I am more relaxed about it than if I lived 100 miles away.
<hr width=100% size=1>Que scais-je?
Many know my problem
I spend periods out of the country and my boat is left in Marina .....
Having returned to a half full boat last spring, due to blocked cockpit drains and filling with rain-water - I altered my auto-bilge-pump arrangements .....
Previously I relied on manual pumps and a wandering lead electric pump to get rid of water in nooks and cranny's. Its still a good idea and the little LV pump for a tenner was great ... even doubled as anchor / wash-down !
Now as in a previous post - I have a Auto-switched Rule 300 sitting wedged in the main bilge area under the cabin sole .... direct fead of the battery and a solar-panel, 5W job from a Car-accessory shop, keeping it charged.
Having left this for a considerable period ..... I can honestly say that a) despite my drains being blocked again the bilge was as dry as the pump could get it ..., b) the battery was NOT flat but in fact well charged, c) the whole caboodle cost me less than 40 quid including charger.
Considering the damage that the flooding did previously and the amount of work it will take to get the woodwork back to normal ..... it has that terrible black stain tide-mark all around ...... I am glad that it is unlikely I shall see the like again on my boat.
I fully agree that a serious leak and/or failed skin-fiitting is a different matter ...... but this post and others was prompted by others who asked whether it is a good idea to have auto-pumps etc.
For any to say forget it, waste of time, no good etc. etc. I think is a dis-service and misguided. I for one have proof that it is worth it and I will do this again on any other boat I own in future.
So there - that's my soap-box for today !!!
<hr width=100% size=1>Nigel ...
Bilge Keelers get up further ! I came - cos they said was FREE Guinness !
/forums/images/icons/cool.gif
MainlySteam
24 Jul 2003
Re: Many know my problem
<<<For any to say forget it, waste of time, no good etc. etc. I think is a dis-service and misguided>>>
Hi Nigel
I think you should get a job as a dramatist or else read peoples' posts properly.
Who, in the two current threads, has said that one should not fit auto bilge pumps? No one that I can see. If I read your posts in the same way as you appear to read others I must assume that you think such pumps are faultless, will run forever, and are the best fix around for a leaky boat.
For my own part I have only pointed out the false trust that many have in them for protecting unattended boats (and I have limited my comments to battery charge only, in fact auto bilge pump systems in small pleasure vessels have a history of being unreliable through a number of other reasons), and pointed out that if one has a leaky boat then my suggestion is that it should be fixed. I have also said that in my own case I considered the care and attendance we take of our boat and the installed battery capacity (more than most) and found that it did not pan out for us.
I suspect my comments, together with those of at least one other, have encouraged some to think about the reliance that can be placed on such pumps (whether they have them already or not). I am sure they will come to their own decisions, perhaps a little more informed than before in doing so, and not on the basis of a whole bunch of posts essentially simply stating "I have one and you should too".
I would appreciate your pointing out to me the very words of mine or anyone elses in these threads which state that one should "forget it, waste of time" etc.
John
Mirelle
N/A
30 Nov 2002
Like John, I hope I have not said "Don't fit one", what I hope I have conveyed is
"I have not got one, and will not fit one, because I am very worried about stray current electrolysis in my wooden boat. I don't think the installed battery capacity would cope with a serious leak, and I don't expect her to start leaking; if she does I will fix it fast."
My boat has a self draining cockpit and of course a cockpit cover; owners of wooden boats which do not have s/d cockpits and who live a long way from their mooring are in a rather different position, I accept, because the cockpit cover can be damaged easily.
I can only reply that obviously you consider my post aimed at you ..... not strictly true.
On reading the posts - no-one actually prints 'waste of time etc. etc.' ....... but some parts get close without saying it. Therefore I don't want those that have no experience - or newbies for want of a better term - to be led to believe that such measures are not advised or not worth it ..... there are two sides to a coin. Safety measures and defensive action is sensible ...... we can all suffer a leaking stern gland or something .... and as said - compartmentalising a bilge is not practical or possible on a lot of the older boats etc. plus many older boats are not self draining cockpits and rain water does get through even with covers etc. - as I found with my previous boats etc.
I have no argument as you will have seen in my posts with the battery / major - or serious leaks etc. BUt I make strong point that there is a place for them - if taken in right context and not over-relied on.
I for one have no choice but to put undue reliance on one - but that is my circumstance and not the norm. The use of and good work that it has done convinces me, along with other boats I have surveyed / been on / have fortune to witness have not suffered by fitting them. I have also seen many a boat that I think should have had one - AS WELL as fixing the problem.
Take my posts as you wish, that is your choice - but I am not in the habit of putting down another. I will leave that to far better writers than me !!!!
