simonfraser
https://leisurelines.net/atwood-ehm...eater-cw-heat-exchanger-220v-1500w-7007-p.asp
is the item
i have taken the metal front cover off to repair the heater, now works again, burned out wire, corroded connector
but i can't get the bottom screw of the cover back on, access is just too poor, be easy if i took the engine out
so, if i drilled some small holes in the front plate, either side of the electric access cover, i'd be able to secure the cover
dont want drill into the wires / pipes behind the outer casing ....
is the item
