michaela
Hi guys I got my boat lifted out yesterday and saw that one of the bolts securing the rudder bottom pivot bracket had been pulled out of the skeg. Looking at the bolts one looks to be an expander type bolts so I'm guessing whatever it was expanding against has corroded or broken down. The other threaded bolt?with nut attached is holding but the whole thing rotates so the nut can't be removed from the bolt allowing the bracket to be pulled from the the bottom of the skeg yet. The bolts are fitted vertically. I'm wondering how I will be able to fit some new bolts back into the skeg and secure them so that the bracket will be able to support the weight of the rudder. I have seen some posts saying epoxy the bolts in, or fibreglass them in or use sikaflex. Sika flex would be easiest, but I can't really see it holding the bolts if the rudder grounds.
What are peoples experience of doing this repair?
