BelleSerene
There's a lot of stuff to remember and a fair bit of 'fetching and carrying' with numbers and rules (i.e is east best or least and what does that exactly mean! And if latitude is LESS than declination but of the same name..do you add or subtract zenith distance??
Buy, download or even better make up your own step by step pro forma so you dont end up leaving something out or adding when you're supposed to subtract. Easy enough to do at home, never mind down below when you're attempting to work up a sight for the first time!
I agree, and I did the same, actually inspired by the Cunliffe book.
I always find it preferable to understand what's going on rather than slavishly follow a formula or mnemonic: if you can picture it it's obvious whether for example to add or subtract ZD. Just as if you picture True North with Mag North and your own heading on an imaginary compass disc, you don't need to bother remembering what CADET is supposed to stand for or recall the relevance of True Virgins Making Dull Companions: you just use common sense and add or subtract an angle.
Personally, I found sufficient clarity in the short Cunliffe book to enable this, and then as you suggest I made up my own step-by-step proforma with diagrams to hand-hold me through the process when too many months have passed since my last practice!
