Stormin Norm
Active Member
I posted the following question on the Marine Power website and received the attached reply, while the reply explains the idea it does not explain to me why I can only go astern at tick over and if there is anything I can do to remedy the cutting out.
Perhaps a users can give me a laymans answer rather than a technical one ?
Many Thanks
Norman
Question:
Having recently purchased my first boat (second-hand) It is fitted with a Mercruiser 3.0 Petrol with an Alpha One stern drive. The engine runs very well but on shifting the gear lever Astern it has a tendency to cut out. I have overcome this by increasing the tick over speed a bit but it now seems to tick over a bit fast. I have noticed a cam type switch on top of the engine which limits the power available astern, so it will obviously only go astern at tick over and no faster. I would be grateful if someone could tell me the reason for this and any other information that might help.
Answer:
On this type of installation (Alpha drive) there is a shift switch which make easier the shifting.In fact when the shift witch is activated,it reduces the timing of the engine which facilitates the shifting.Regards
Many Thanks
Norman
Question:
Answer:
