Billjratt
Professional sparks is fitting an Argofet (Victron) splitter to replace a normal diode splitter in my boat, which also has a smart controller fitted.
This is the first time I have come across this type of splitter, and Googling for info only causes confusion:
I know they are transistors rather than diodes, and can see there is an "energise" connection (and a signal ground) which I assumed would be the gate to turn on the FETs, but the documentation seems to indicate that this is an optional terminal which can be used to energise the alternator field (in a six-diode configuration I assume).
Has anyone out there the definative answer, and, is there a feel for how reliable they are as compared with normal diode splitters.
I can see the advantage of the decreased voltage drop, but that doesn't matter to me as the battery-sensed smart controller takes care of that.
I would have thought the gate should be permanently internally pulled "up" or used a a soft start if needed.
Any of your experience would be appreciated.
Thanks in anticipation,
