malc60
I,ve just bought a rodman 38 with yanmar 370s , only done 500hrs, they sound fab but dont know anyone who,s got any knowledge of these, have you?
god, i hope not !
thank you firefly625, really apprieciate that
still waiting for Latestarter1.... but to put your mind at ease.... just found this info..The engine group you are looking at is the 6LY series. At 370 hp they are very good engines. 354 cubic inches, 1400 pounds, quiet and don't drink alot. That same engine block, now common rail has models up to 480 hp.
Great engine but don't like overloading, make sure you check that at WOT there is no black smoke, even though the engine is rated at 3300rpm it should be propped for at least 100rpm above. check the colour of the boat transom.
the engine should easily start with some blue/smoke which will clear as the engine gets warm, you will get a fair bit of black smoke under acceleration.
However, maintenance is is the main factor lots of lovely maintenance. regular oil changes at least once a year. make sure the fuel is clean
Fuel lift pumps can be troublsome
Otherwise, a proper Yanmar.
Hi All
I am looking at re-engining a boat and thinking about a set of 2008 yanmar 370hp and putting them on volvo DPH drives. Has anyone done this and do you know if you can get any more HP out of them?
