GHA
Moving on from a few interesting battery threads recently, how about using an arduino to test how much capacity your batteries actually have?
(as I have one in a locker
Briefly, arduino make relatively cheap processing boards used much by diyers with easy ways to connect multiple devices with the outside world.
http://www.arduino.cc
Also very cheap are sensors for measuring current, temp etc and all easy way to log data to a micro sd card of onto the Web.
So, with a little programming and some bits it should be easy to connect a c/20 load to a battery and log current, temp and voltage over time down to 10.5v.
Or even cleverer, have a load connected through a power Transistor controlled by the arduino so the current remains constant as the voltage drops.
Away from the boat so haven't started playing yet, most looks fairly straightforward though not so sure about control of a Transistor. Or cheap loads, maybe 6v motorcycle lamps? Will allow testing of both 6v & 12v batteries.
Any thoughts/suggestions anyone?
Does anyone ever actually do an accurate capacity test?
