Araldite Melting point?
Spyro
18 Jan 2003
Clyde
After a bit of Googling I've discovered that it starts to soften around 65 degrees C but can't find out if it goes hard again when cooled.
machurley22
19 Jan 2004
Scotland
It may well harden again but it won't be a strong adhesive any more.
How useful would that be though? Stuck something in the wrong place? Just heat it up, move it around and allow to cool. Job done. /forums/images/graemlins/smile.gif
sarabande
6 May 2005
the lap shear strength charts show that it is the time spent at a high (say >60deg C) temp which is critical for the "strength" of the bond, and not so much the temperature itself.
There are so many versions of araldite, that it is difficult to answer the OP's q, without more details.
This .pdf is for Araldite 2011
http://av.rds.yahoo.com/_ylt=A0geuncrT95...ata/ara2011.pdf
Page 4 has some revealing charts.
Spyro
18 Jan 2003
Clyde
Exactly right Silkie. Involves a tiller pilot Cantilever Bracket. Thats all I'm prepared to say /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
TigaWave
17 Dec 2004
Buckland Monachorum
www.H4marine.com
I use and advise the use of Araldite 2011, also known as precision (blue and white tubes) as a thread lock sealant for underwater stainless, bronze and composite items as well as composite bearings, as this is a low temperature epoxy.
Softens for bearing removal at around 60-70, 90-100 it is runny and bearings slide out easily.
Other araldites are higher melting softening temp.
Shearwater
19 Oct 2005
Felixstowe Suffolk UK
Ah! Used Araldite to stick a s/s saucepan lid handle back onto the lid. Thought it would be right for the job....i.e. what else could I have used? Thus far no dramatics in the kitchen department.
footsoldier
4 Aug 2006
UK and France
ColinWB
Snap! I did the same repair 4/5 days ago and guess what, the bugger fell off tonight. Yours will too, I imagine. Never realised Araldite melted at relatively low temperature.
Non-boaty, but I really could do with a suggestion for a more suitable adhesive for fixing handle to saucepan lid. (matching set, too tight to buy replacement etc etc)
William_H
28 Jul 2003
West Australia
Posters seem to be referring to the standard handyman Araldite. However Araldite is just a brand and they manufacture all sorts and grades of epoxy. They do a high temperature grade. Various other resins can also be had in high temp types. ie Vinyl Ester or polyester. You need to check the data sheets. olewill
whiteoaks7
29 Nov 2002
South Wales, UK
www.seasolutions.co.uk
A bit late perhaps: epoxy resin is not generally a thermo plastic, once set it stays set. In my previous incarnation I often had to use a burning torch to remove the stuff, it didn;t melt just degenerated until it could be dug out. So as someone said - depends on the actual stuff, not the brand name. Also generally, two part plastics are thermo-sets, ie dont re-melt when heated.
ianat182
10 Jul 2008
,home Portchester
Try using a tube of 'Chemical Metal' made by those Plastic Padding people I think, supposed to be drillable and tappable when set.( this for the saucepan repair !)
