Aquastar 33 with twin 225hp diesel - what performance to expect?
Paul-F
Active Member
18 Mar 2012
Jersey, CI
As per title, what speed for cruise and top end would one expect from twin 225hp diesels in an Aquastar 33? What would the fuel consumption be approximately at those speeds?
Ta.
Paul.
I believe that’s a semi displacement boat ?
A friend has a 38ft Broom with twin 250Hp and that goes okay = 23 knots – so I would say a 33 of a similar design philosophy with twin 225’s would be similar.
No idea what the fuel consumption would be but liable to be fairly high unless you are happy to go slow.
I had the same boat for 7 years, but with two Cummins B series (turbo) lumps which were rated for 210hp per side.
I might have seen 20knots once...downhill. More like 16 knots cruise on a good day.
Overall fuel consumption was approx. 0.9NM/gallon with typical usage being 20% displacement and 80% above.
I had a Halmatic 34 with pair of Sabre 265 about 7500 kg, it was overpowered and would top out at 25 knots but cruise all day 21 knots.
A typical read-out from a few years back: me cruising away from a Solent full of AIS transmissions during Cowes Week:
Thanks for the info - I'll assume 15kts cruise. and 1mpg for my calculations! Just weighing up the pros/cons of some older boats .....
My Corvette is 32' with the Cummins 210s, and presently with clean hull she pulled 18.7 knots at WOT and 2700 RPM. If I reduce to ~2400 she will cruise happily all day ~ 14-15 knots and I expect about 1.5 MPG.
If I put her bum in the water at a sedate 8 knots at ~ 1600 RPM the tanks hardly seem to move and I reckon I am getting above 3MPG, increasing to near 4 or even 5 at 6 knots river speed and 1,100 RPM.
If the props become fouled with barnacles forget all the above. Before she cam e out a few weeks ago I could not get her above 10.5 knots / 2100 RPM wallow.
I would expect the Aquastar would be broadly similar.
