Aquagen towed impellor - replacement
Ric
8 Dec 2003
Some pikey nicked the Aquagen ATMB towed impellor last night - sailing along nicely then a bang and it was gone.
Replacements are absurdly priced - over €300 for a 90cm piece of 316 steel.
So I want to make my own. I can buy a new set of 113mm blades for about €40 which is reasonable,
But what I can’t remember is whether the mounting for the blades is pitched? Or do they just mount at zero pitch and all the pitch is in the blades themselves?
I should have taken measurements and photos before it got nicked. If anybody has one they could measure/photo/weigh as a template would be most helpful.
Thanks - yes I can see from the pics that the blades are indeed pitched, which will make it a bit hit and miss to make another one. Maybe not worth the bother.
I guess I’ll have to buy an OEM version but make sure I take all the measurements and angles so I can make another if necessary.
There is a plastic fitting at the end of our shaft and from memory the pitch is about 30 degrees. I made replacement blades from stainless plate for ours, I wanted smaller than the smaller of the 2 blades supplied. If we make 10 knots the shaft leaps out of the water/waves. I simply rounded the leading edge of the new blades and thinned the metal off - works fine. From memory the blades are secured with 2 x 3 or 4mm bolts with a recessed Allan key head
I guess you could machine the plastic fitting to make a new hub/boss (?) but equally you could simply weld a couple of blades on to a hefty stainless rod - its not very sophisticated.
Jonathan
The aerogen blades look like cut down turbine blades.
Thanks - if Rappey could measure the pitch angle then I will make my own version. The OEM blades are only €40 so I would prefer to use them rather than just weld on some flat steel blades.
I agree pitch looks about 30 degree - but would like an exact measurement if I can get one.
Hope you can extract something sensible from the pics.
Looks to be 14 to 15 degrees ,ignoring the curved over part
