wellf100
Hi all, here's my review and findings after 1 year of using Aquacote foul release rather than traditional antifoul. I'm based in Guernsey.
As mentioned in previous threads, I got my boat ready for the season in April last year and didn't enjoy stripping off the old flaking antifoul. I saw the Aquacote article in MBY and decided to give it a a go given it's multi season claims and a price, which after discount, made it equal to the cost of priming and antifouling. Today I took the boat out of the water for the first time since May 2015 to do various jobs so I thought I would give an unbiased review of how the Aquacote has performed after the first year.....
To be clear, the product is a 'foul release' system not an antifoul. So growth will occur as it would on a bare hull, however the idea is it can be very easily wiped away or drop off at speed. The company recommend regular cleaning with a squeegee or Srubbis brush at least monthly however in reality this isn't really practical. It's easy to give the water line and transom a quick wipe over while in the water but not so easy underneath. As it's a small boat (5.2m) I just cleaned the hull by swimming around with a long handled squeegee and wiping away any growth. I did this maybe twice during the summer, the last time being in September. It took me about 15 to 20mins of swimming to clean each time... which was good exercise and free
The underside and most of the transom were very easy to wipe clean. In between cleans just the movement through the water at 25 knots was clearly enough to knock off anything big that tried to take hold as there was never anything other than a thin layer of muck when I inspected it underwater.
Now that I have the boat out of the water and after 6 months of not being cleaned underneath at all, it's a good opportunity to see how it looks.....
Here's the underside today on dry land. You can see where the slime has wiped off from where the boat slid across the trailer rollers when I loaded it on.
after wiping some areas with squeegee
Here's a video of how easy it is to wipe clean. The surface looks pretty much good as new once cleaned. I must admit I'm pleasantly surprised as I didn't expect it to be quite so effective. All in all a good result.
However....across the year it was noticeable that it wasn't so effective around the waterline. Primarily on the stern quarters. The wispy weed that grows here proved much more stubborn and didn't wipe off so easily. I was forced to scrape it off more aggressively and regularly which was a pain.
I'm not sure whether this type of growth beats the system or if it was my poor application of a second coat of the top coat. A second coat is recommended around the waterline but the roller wasn't in great condition when I applied it and I suspected at the time that it may not cure as smoothly as the rest. Once I've got it cleaned up I will apply another layer of top coat and see if it helps this season.
I've no intention of applying another top coat layer on the rest as it all looks in perfect condition and is working very well.
Last year I avoided grounding the boat as I was concerned about damaging the top coat and reducing it's effectiveness. However I think this year I will be braver and see if grounding has an impact on it. If the surface is scuffed then I'm sure it will be effected as it relies on a super slick surface but I don't know how much impact or scuffing it take to damage it. I still have a fair bit left over in the tin and it can be touched up or re-coated at anytime so not too worried.
All in all I'm very pleased. So far it matches the manufacturers claims and there's no evidence of any degradation of the surface after a year in the water so I've no reason to disbelieve the multi year claims.
Hope this is useful!
Cheers
Rich.
p.s. I'm not connected to Aquacote in any way.
Cheers
Rich.
