brp
New Member
I have twin 1989 aqad41a's on 290dp's which have been running very well.Recently the port engine just started overheating under load but as soon as i throttle back to around 1600rpm the temp comes down and sits at normal reading.Tried all the usual suspects, seawater pump,heat exchanger, flow restriction, exhaust elbow and even flushed acid through the system to try and clear any build up of deposits.Mechanic is now pointing towards cylinder head gasket although i have no loss of power, no white smoke or steam, no signs of water contamination in the rocker cover.The freshwater level has started to drop recently and the mechanic did find the freshwater pump slightly nleaking through the seals which he thinks may be getting blown out due to exhaust gases getting down into sump and causing this hence his pointing to cylinder head.I had a compression test done a few months ago and all was fine.
Would appreciate any help/advice on this matter as i am still convinced it is a flow problem
