Aq205a carb issue
xxmartinxx
1 Dec 2020
Aq205a carb issue
Hi I have a fairline weekender 21 with aq205a & dp290 volvo-penta, the issue I have is my carburetor (quadrajet 4bbl 17088142, 0799 ) run really well in tick over pulls away ok but when I go full throttle it starts fogging, I have recently serviced, I did by the carburetor 2nd hand
Most common cause would be water in or bad fuel. Or the usual crap stuck in the non return valve in the fuel line between tank and filter. Occasionally the pick up pipe in the tank can get blocked under high fuel demand too. Start with looking at what comes out the fuel filter. If it’s had any sign of water through it, the carb 9/10 times needs to come off for a clean. Good luck.
