FullCircle
I have been looking at their 2:1 and 4:1 cars and towing endstops.
Anyone comment on their use and reliability?
I have only sailed on one boat with towable cars. The idea being to be able to adjust the for and aft position of the cars from the cockpit. Th9is is very desirable with a furling jib.
The system I have seen uses bungee to pull the cars backward and 2 to one purchase to pull the car forward.
If I remember correctly it is only possible to move the cars with very little load on the jib. With a ton or so of load on the car and track it would take a very good ball bearing system to enable the cars to be moved especially forward even with 4 to 1 tackle.
I suspectt you would be expecting to much to be able to adjust under load. good luck olewill
I have old Lewmar ball bearing cars, with 4:1 purchase, and can't budge them without easing the sheet and then winching back in when the car has been moved forward. I can't see how the geometry would allow the cars to be moved unless the sheet was stretchy!
I think I am doing it correctly but ready to be told otherwise!
