Baggywrinkle
I have a Mercury 9.9hp EFI mounted on the pullpit rail, and a crane to lift it ... but I have 3 problems ...
1. The crane is too short to lift the engine high enough to clear the outboard bracket on the rail and is only rated for 35kg ... the engine is 38kg and it wobbles a bit.
2. The outboard bracket is very high, protruding 2 inches or so above the rail.
3. The outboard is large and an awkward shape such that the lifting harness the previous owner left doesn't fit.
I'm going to replace the crane and the bracket to increase clearance, but I can't find a suitable harness to lift the engine, and the engine doesn't have a lifting eye under the cowl like my old 6hp Merc did ;(
Anyone else solved this problem or recommend a harness for a similar sized and shaped engine?
