Anyone know what kind of boat
wingcommander
25 Jul 2013
As title says. Chap in boatyard purchased this practically unseen with no history/paperwork. Just curious to know if any light could be shed on his project.
Did get his permission to enquire for him .
Over to the experts
Cheers
What is her construction material - it looks like plywood?
That is an interesting rubbing strake (for want of a better word) halfway up the topsides.
She is probably a home built boat, possibly from bought plans - she looks like a nice design.
You might get a better response if you ask this question on the Motorboat forum.
Hi , yea the buyer was told she had some kind of military history, however very limited information. All plank construction, not sure of the double diagonal meaning. Ime back at the yard this weekend if their is anything I could look For?
I can see vertical lines of what appear to be screw holes in the topsides, and they seem to be uniformly spaced, perhaps because they are in way of the frames?
If she is of planked construction, then the topsides are exceptionally fair.
A very left field thought - I wonder if the topsides are plywood, screwed to the hull frames, and maybe that 'rubbing strake' halfway up the topsides is a sort of improvised 'butt block' over a joint between the plywood sheets?
Maybe they could not (for reasons of hull shape perhaps) put the plywood panels on for the full depth from sheerline to chine, so they had to use two panels instead?
Do you know what the new buyer intends to use the boat for?
What does she look like inside - is she gutted, or does she have furnishings?
My money would be on it being that the hull was a seaplane / ASR tender probable 1950s .
Agree. DD below that rubbing strake and maybe ply above.
I looked at the image in an image editor, and it's clear that the diagonal planking extends up to the gunwale. The pronounced striping below the "strake" is still there, just less obvious.
I think she's double diagonal. For the OP's benefit, that means that there are two layers of planking running in different directions, usually separated by a glue-impregnated layer of fabric. Many military craft were built that way; it's strong, light and easy to fabricate. The drawback is that if water gets between the layers and the wood begins to rot, it can be very difficult to repair. Perhaps not difficult in the sense of requiring great technical skill - more that rot in one plank will almost certainly result in rot running in a different direction in adjacent planks, so what initially appears to be a small patch of bad wood ends up requiring a lot to be replaced. If she's as old as people think - 40s or 50s - the glue in the fabric layer will probably have started to deteriorate, too.
Military craft were, in general, not built for a long life.
I'm 99% sure she is British Powerboat Company, the angle of the topside planking is the clue.
The bottom is double diag. Layer of oil impregnated cotton in between, no glue.
The topsides are single layer with battens internally along the seams, known as'seam battened topsides', the builder had a patent for this method of construction.
I'm not an expert, but I have owned two BPBCo boats.
