William_H
No, if you turn up the input to a an amp rated at "60W into 4ohms", then a "30W 4ohm" speaker will get 60W.
Give or take the fact that speaker impedances are complex and amplifier manufacturers often exaggerate their power.
So, you'd want to keep the volume turned down some. Quote
Quite so higher wattage amp means higher voltage. The speaker will bottom out in its travel so giving distortion not a problem to you although the cone can be distorted and damaged as can the voice coil itself. The next problem is that the voice coil is made of as light a wire as possible to reduce weight so can be melted (fused) so run 60 w into a 30 w speaker at your (speaker's) peril. olewill
Also, most speakers designed for music or PA won't like being used at a high duty cycle, it's a peak rating, not continuous. Probably no issue for normal yacht fog signals.
