scottie
Like yourself, I am a long term owner (16 years).
Just a thought, you are probably aware that their is a copper pipe going through the block where water always passes irrespective of the coolant temperature.
Any blockage is liable to be in the engine galleries circuits which then lead to the thermostat and then into the exhaust elbow. I found it essential that the thermostat must be taken out when using brick cleaner to have any effect on the blockage.
I found it easier just to take out the thermostat and cover , then pour the liquid in directly into the engine galleries. It is very comforting to see and hear all the fizz. Also, the drain plug is on the left hand side of the engine as you look at it, and you may have to shove a small screwdriver up there to let all the crud out. Mine is always blocked.
Apologies. Just realised that you have a VP2002 . I have a VP2001. Things might be arranged differently.
As an aside, I have always been led to believe that these engines were designed to be raw water cooled right from the start which is unusual. They therefore were designed much thicker in the waterways department than the usual engines which are converted for marine use. Can anyone confirm this ? .
Yes and when supplied via a dealer the dealer had to convert them except for 2003T
A conversion kit was supplied as an accessory and was cheaper than the heat exchanger or water pump on their own
