rlea
Active Member
Hello.
The rear starboard mounting on my 3 cylinder perkins is shot.
Before I have a go at replacing it, I thought I'd post a thread to see if:
a, I've got the job planned ok and
b, Someone may be able to pass on advice to make the job a little easier?
The plan is to take the old mounting off in my local marina on the water. The engine sits too far back to put a sling around and take the pressure off so I'm hoping to jack the rear end up, failing that, there is enough thread to screw the old mounting down a cm or so, then chock the rear end and let the engine down.
I'm not planning on taking the prop off as there should be enough play in it to leave well alone. That's it, apart from shearing the heads of bolts and not being able to find a replacement part, I can't see any problems.
What do you think!
What do you think!
