Any thoughts on Digital Yacht AIT5000 AIS?
Blue Seas
29 Jun 2024
I want class B+ and also 0183+NMEA200 + WIFI so my choices seem to be limited - any thoughts on this unit or Digital Yacht gear in general?
Ta.
Ta.
It's made by SRT, the parent company of Em-trak, same as the Emtrak B924. I could supply the Em-trak one for much less than the Digital Yacht.
I'm thinking of going down the B593 route and adding in a DigitalYacht NavLink2. The combo seems to be about £40 cheaper if you shop around, plus you can get other NMEA2k data over WiFi, such as speed/depth etc, which I don't think the WiFi on the B594 will do, as I believe it will only send it's own GPS and AIS data, not anything else on the network.
I had a Digital Yacht CLB2000 in Greece. Worked perfectly doing just what it said on the box. Sent a useful record to Marine Traffic, allowing interested parties to follow our progress. Perfectly reliable for a number of years.
That's incorrect, the current B900 series multiplexes NMEA0183 and NMEA 2000, early models may need a firmware update.
Ah, I stand corrected. I hadn't released the firmware update had arrived. Maybe a B594 is the best option to keep it simple.
The update was released early 2024.
By default any data received on port 1 will be output on port 2 and over Wi-Fi / Bluetooth.
Also by default any data received on port 2 will be output on port 1. To multiplex that data received on port 2 over Wi-Fi / Bluetooth as well, please send the following command:
$PSMT,0,3,0x2C75B2FA,0,nvseti “nmea2mux”^2C0x5^2C2^2C0^2C0,0*7C
