Concerto
I am having to remove my water tank to get a small leak repaired. On my Westerly Fulmar it islocated under the cockpit and was fitted before the deck was fixed. The tank is fixed down with 4 bolts. I have removed 3 of them. The 4th is shown by the blue arrow. It can only be accessed via a small hole and is about 24" away. My initial thoughts are to either drill around the bolt so I can break it out or to take my multitool with a saw blade and cut a slot in the plywood to push the tank aft to release the bolt. It might be possible to use the multitool to cut the head off the bolt with a metal cutting blade, but it is a 4mm and will be difficult There is no way to reach the bolt without cutting into another bulkhead in the quarter berth, which I am very reluctant to do. Any other ides?
