simonfraser
with the engine not running ?
its a diesel KAD 44, i have shore power charging the batteries
That wouldn't happen with the ignition just left in the on position though would it?
reason is forwarding the hours on the tacho.
these are lagging behind the hours stored in the diesel engine.
i can power up the hours display from a separate 12V 24/7 feed and let it run, this should work. spannerman has kindly confirmed the wire color codes.
i will experiment over the weekend, initially just leaving the ignition on for an hour to check it does advance the hours recorded.
i then have the choice of setting up a separate feed or just leaving the ignition on for about 15 days.
second option is simpler & allows me to still use the boat without extra wires / hassle of removing and installing the tacho again.
so assuming i don't have relay / wire faults, is there any harm in leaving the ignition on for the required time ?
just throwing a question out there. Does it have to be 12V? Could you not just temporarily hook up a 9V PP3 battery instead and save yourself the doubt?
So what? Whatever the difference, it's sufficient to note what it is and be done with it.reason is forwarding the hours on the tacho.
Well it did.
Key didn't spring back & starter was still being powered after engine start.
Which is not what the OP is asking about. He’s not talking about running the starter for days (!), only powering up the ignition circuit.
(Though his subsequent idea of just powering the instrument he’s interested in seems like a better one.)
