Daydream believer
You may have missed the point a little. If the mast did slip & fall on the OPPOSITE side of the boat whilst still attached to the jib. It will have the effect of pulling the crane outwards. I found in my test that it took significantly less weight to cause the wheels on the opposite side of our gantry to lift off the ground, when I started to swing the weight thus.. To explain this a bit clearer, imagine the jib set at its max reach, with the weight near the ground . Then looking from above swing the weight in a circular motion. At some point the weight will swing beyond the reach of the jib. That creates the effect that I felt might come about in an accident. Hence I took steps to re create it & measure the weights.I find myself in total agreement with what you have stated (especially the last sentence!).
As my proposed crane can rotate about a vertical axis, the risk of the mast falling at an angle is diminished.
The tests we performed with the original boom were with ~300kg. That was with the boom horizontal which is a worst case. With the boom near vertical, the test is less onerous.
Useful input.
The exercise also took into consideration side loads on the jib to test twisting which happens when the weights are swinging right angles to the jib.
I think that if I had to stand in front of a coroner & explain what I did I think that he would consider that as a sailing club we had taken due care & consideration
